Eco X Gear Battery Replacement
  1. Eco X Gear Battery Replacement, Frame: step 1, image 1 of 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: step 2, image 1 of 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: step 3, image 1 of 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: step 4, image 1 of 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: step 5, image 1 of 1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: step 6, image 1 of 2 Eco X Gear Battery Replacement: step 6, image 2 of 2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: step 7, image 1 of 1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: step 8, image 1 of 1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: step 9, image 1 of 1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
James Lipsett
625 Reputation
6 Guides authored
3 Comments
Where to get the new battery?
James Chen - Reply
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 37
All Time: 733
