Eco X Gear LED Display Replacement
  1. Eco X Gear LED Display Replacement, Frame: step 1, image 1 of 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear LED Display Replacement: step 2, image 1 of 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear LED Display Replacement: step 3, image 1 of 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear LED Display Replacement: step 4, image 1 of 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear LED Display Replacement, LED Display: step 5, image 1 of 1
    • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
  6. Eco X Gear LED Display Replacement: step 6, image 1 of 1
    • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
James Lipsett
625 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 227
