Introduction
Follow this guide to remove a carburetor on the Edco Cement Saw KL1465H, either for cleaning or replacement.
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic spark plug cap at the end of the spark plug wire.
Firmly pull to disconnect the spark plug cap from the spark plug.
To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
Use your fingers to unscrew and remove the wing nut securing the air filter cover.
Use your fingers to unscrew and remove the wing nut securing the air filter.
Use a 10 mm wrench to remove the two nuts securing the air filter elbow to the carburetor's threaded rods.
Pull the air filter elbow straight off of the carburetor's threaded rods.
The breather tube on the rear side of the air filter elbow should come out with the elbow. If you have difficulty removing the elbow because of the breather tube, use your fingers to loosen its press-fit connection to the engine's valve cover.
Pull the carburetor spacer straight off, making sure it clears the threaded rods.
Pull the choke lever straight up to remove it from the carburetor.
Use a pair of needle nose pliers to squeeze and loosen the spring hose clamp on the fuel supply hose.
Move the clamp up 2-3 cm so it's not clamping down onto the end of the tube.
Pull the carburetor halfway out, but do not completely remove it yet.
Pull the carburetor straight off of the threaded rods to remove it.
