Introduction
Follow this guide to replace a damaged engine on the Edco Cement Saw KL1465H.
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic spark plug cap at the end of the spark plug wire.
Firmly pull to disconnect the spark plug cap from the spark plug.
To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
Remove the arbor guard.
Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
Remove the belt guard.
Use a 9/16-inch wrench to loosen the lock nut on the engine's tap bolt.
Use a flathead screwdriver or a 3/8-inch wrench to remove the screw securing the drain hose to the concrete saw.
Slide the engine forward on the frame to relieve tension on the belts.
Remove the outer belt from the engine and arbor pulleys.
Repeat the process for the inner belt.
Use your fingers to unscrew and remove the wing nut securing the air filter cover.
Use your fingers to unscrew and remove the wing nut securing the air filter.
Use a Phillips #2 screwdriver to remove the screw securing the throttle cable to the engine.
Grab the throttle cable clamp with your fingers and rotate it out of the way of the throttle cable.
Unclip the blue wire connector on the front of the engine.
Remove the wire connector from the engine's switch wire.
Use a 1/8-inch hex key to loosen the two set screws on the engine's drive pulley.
Use a 9/16-inch wrench to remove the three engine mount nuts and the ground wire at the front of the engine.
Use both hands and carefully lift the engine straight up off the concrete saw to remove it.
Place the engine on your work surface and prop up the rear by placing a wooden block underneath it.
Use a 5/8-inch wrench to unscrew and remove the drain bolt from the engine.
