Edwin the Duck Rubber Gasket Seal Replacement
  1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: step 1, image 1 of 2 Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: step 1, image 2 of 2
    • Unscrew the four 9mm screws with aT8 bit
    • Take the back plate off
  2. Edwin the Duck Rubber Gasket Seal Replacement: step 2, image 1 of 2 Edwin the Duck Rubber Gasket Seal Replacement: step 2, image 2 of 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin otherwise you will lose the waterproof cover.
  3. Edwin the Duck Rubber Gasket Seal Replacement: step 3, image 1 of 1
    • Using the J1 bit, unscrew all six 9 mm screws around the border.
  4. Edwin the Duck Rubber Gasket Seal Replacement: step 4, image 1 of 2 Edwin the Duck Rubber Gasket Seal Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Rubber Gasket Seal Replacement: step 5, image 1 of 2 Edwin the Duck Rubber Gasket Seal Replacement: step 5, image 2 of 2
    • Remove the rubber gasket
  6. Edwin the Duck Rubber Gasket Seal Replacement: step 6, image 1 of 1
    • Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
Nadia Dobrogorskaya
131 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2017 Member of UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 7
All Time: 377
