Edwin the Duck Speaker Replacement
  1. Edwin the Duck Speaker Replacement, Speaker: step 1, image 1 of 2 Edwin the Duck Speaker Replacement, Speaker: step 1, image 2 of 2
    • Unscrew the four 9mm screws with a T8 bit
    • Remove the back plate off
  2. Edwin the Duck Speaker Replacement: step 2, image 1 of 2 Edwin the Duck Speaker Replacement: step 2, image 2 of 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in not having a waterproof cover.
  3. Edwin the Duck Speaker Replacement: step 3, image 1 of 1
    • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Speaker Replacement: step 4, image 1 of 2 Edwin the Duck Speaker Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Speaker Replacement: step 5, image 1 of 2 Edwin the Duck Speaker Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, pull up the black tab up until it stops.
    • Be careful not to pull the black tab too far up, otherwise the cable won't be able to secure anymore.
    • Pull up the white cable tab up slowly
  6. Edwin the Duck Speaker Replacement: step 6, image 1 of 2 Edwin the Duck Speaker Replacement: step 6, image 2 of 2
    • Use the J1 bit to unscrew all four screws attached to the motherboard.
    • Use the J1 bit to unscrew both 9 mm screw attached to the white plastic plate.
  7. Edwin the Duck Speaker Replacement: step 7, image 1 of 1
    • Lift up the motherboard and speaker, and place to the side like done so in the image.
  8. Edwin the Duck Speaker Replacement: step 8, image 1 of 2 Edwin the Duck Speaker Replacement: step 8, image 2 of 2
    • Take the speaker and by using the soldering iron, unsolder by the red and white wires.
    • For more detailed information on how to solder and desolder connections, please see this guide.
    • Replace the new speaker and solder the two wires back into place. The red wire goes on the left and white wire goes on the right.
Tanner Mowbray
101 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2017 Member of UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 287
