Electric Bike Throttle Replacement
  1. Electric Bike Throttle Replacement, Brake: step 1, image 1 of 1
    • Before starting to disassemble your electric bike, turn the power off.
    • Remove the 3/32 inch Allen screw.
    • When removing Allen screw, make sure the driver is well seated because they are simple to strip.
  2. Electric Bike Throttle Replacement, Throttle: step 2, image 1 of 1
    • Locate the throttle Allen screw.
    • Remove the 5/64 inch Allen screw.
  3. Electric Bike Throttle Replacement, Throttle: step 3, image 1 of 1
    • Slide the Throttle off.
    • When removing the throttle, be careful. Remove it slowly to avoid damaging the wire.
  4. Electric Bike Throttle Replacement, Control Box: step 4, image 1 of 1
    • Remove the following screws.
    • 2 mm Philips screws.
  5. Electric Bike Throttle Replacement: step 5, image 1 of 1
    • Open up the control box.
  6. Electric Bike Throttle Replacement: step 6, image 1 of 1
    • Track the throttle wire.
    • To ensure you don't lose it, you should mark it.
  7. Electric Bike Throttle Replacement: step 7, image 1 of 1
    • Locate the throttle wire.
    • Disconnect the throttle wire plug from the controller wire plug.
    • Take caution while handling these wires. You can easily damage them.
Ali Al-hamadani
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,860
