Electrical Plug Replacement
  1. Electrical Plug Replacement, Two-Pole Plug: step 1, image 1 of 2 Electrical Plug Replacement, Two-Pole Plug: step 1, image 2 of 2
    • Be sure to unplug the lamp.
    • Locate the damaged portion of wire.
    • Cut the damaged plug from the lamp cord one inch below the damaged area
  2. Electrical Plug Replacement: step 2, image 1 of 2 Electrical Plug Replacement: step 2, image 2 of 2
    • Separate the wire by gently pulling it apart.
    • The wire with the raised ribbing on the coating is the neutral wire.
    • The hot wire has a smooth coating.
  3. Electrical Plug Replacement: step 3, image 1 of 3 Electrical Plug Replacement: step 3, image 2 of 3 Electrical Plug Replacement: step 3, image 3 of 3
    • Strip the coating off the wire.
    • Expose 3/4" of the copper wire.
    • Twist the exposed copper wire so that there is no fraying.
    • Twisting the wires ensures the strongest connection and maximum safety.
  4. Electrical Plug Replacement: step 4, image 1 of 2 Electrical Plug Replacement: step 4, image 2 of 2
    • Loosen the screw and open the replacement plug.
    • The silver screw is the neutral connection, and the brass screw is the hot connection.
    • The different connections must be determined in order to properly wire the replacement plug.
  5. Electrical Plug Replacement: step 5, image 1 of 3 Electrical Plug Replacement: step 5, image 2 of 3 Electrical Plug Replacement: step 5, image 3 of 3
    • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
    • Remember the neutral wire is the wire with raised ribbing on the coating.
    • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  6. Electrical Plug Replacement: step 6, image 1 of 2 Electrical Plug Replacement: step 6, image 2 of 2
    • Thread the cord so the plug will completely close.
    • Tighten the exterior screw to close the plug.
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
19 other people completed this guide.
Tim Spellings
583 Reputation
1 Guide authored
Texas Tech, Team 3-2, Rauch SU 2015 Member of Texas Tech, Team 3-2, Rauch SU 2015
TTU-RAUCH-SU15S3G2
3 Members
4 Guides authored
7 Guide Comments
Passt - gute Anleitung
Martin Winter - Reply
A version for 3 prong (North American) would be great
James Harrison - Reply
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - Reply
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - Reply
Buy a plug that can be opened with a screw
Toon Konings -
Past 24 Hours: 9
Past 7 Days: 70
Past 30 Days: 351
All Time: 52,260
