Electrolux LTE12 - Washing Machine Disassembly
  1. Electrolux LTE12 - Washing Machine Disassembly, Electrolux LTE12 - Washing Machine Disassembly: step 1, image 1 of 2 Electrolux LTE12 - Washing Machine Disassembly, Electrolux LTE12 - Washing Machine Disassembly: step 1, image 2 of 2
    • Unplug the wall outlet.
    • Release the water hose.
    • Loosen the 4 Phillips screws at the top and 2 1/4 screws below.
  2. Electrolux LTE12 - Washing Machine Disassembly: step 2, image 1 of 1
    • Fasten the lid of the washing machine with a large crepe tape. Do not open when removing the top of the machine.
    • There is no need to remove the glass cover to remove the top of the machine.
  3. Electrolux LTE12 - Washing Machine Disassembly: step 3, image 1 of 1
    • Open the top of the washer. Lift the back first. And then the front.
    • Grip the top of the machine with care. Take care not to drop and break the cover glass.
    • Release the power cord and hose clips from the pressure switch.
  4. Electrolux LTE12 - Washing Machine Disassembly: step 4, image 1 of 1
    • Remove the Phillips screw.
    • Remove the two plastic fasteners.
    • Remove the protective cap (semi-transparent) on the left side.
  5. Electrolux LTE12 - Washing Machine Disassembly: step 5, image 1 of 1
    • Remove the two Phillips screws.
    • Remove the protective cap (semi-transparent) on the right side.
  6. Electrolux LTE12 - Washing Machine Disassembly: step 6, image 1 of 1
    • To loosen the Control Panel cover, loosen the two Phillips screws. (Left side).
  7. Electrolux LTE12 - Washing Machine Disassembly: step 7, image 1 of 1
    • To loosen the Control Panel cover, also loosen the two Phillips screws on the right side.
  8. Electrolux LTE12 - Washing Machine Disassembly: step 8, image 1 of 1
    • Carefully lift the cover of the Control Panel. In this photo, the glass cover was removed to enlarge the image.
  9. Electrolux LTE12 - Washing Machine Disassembly: step 9, image 1 of 2 Electrolux LTE12 - Washing Machine Disassembly: step 9, image 2 of 2
    • If there is a need to replace the Power Circuit Board, carefully pull out the program select button.
    • And then loosen the two Phillips screws.
    • Disconnect the cables carefully.
  10. Electrolux LTE12 - Washing Machine Disassembly: step 10, image 1 of 2 Electrolux LTE12 - Washing Machine Disassembly: step 10, image 2 of 2
    • To remove the circuit board from the Panel buttons, remove the three Phillips screws. Disconnect the cable carefully.
    • When removing the circuit board from the buttons, be aware of the three button springs.
  11. Electrolux LTE12 - Washing Machine Disassembly: step 11, image 1 of 3 Electrolux LTE12 - Washing Machine Disassembly: step 11, image 2 of 3 Electrolux LTE12 - Washing Machine Disassembly: step 11, image 3 of 3
    • If you need to replace any components on the button circuit board, loosen the three Phillips screws to remove the acrylic shield.
    • The problem with my machine was the power button. With a soldering iron and a sucker, I switched on the power switch.
  12. Electrolux LTE12 - Washing Machine Disassembly: step 12, image 1 of 1
    • To change the pressure switch, cut the clamp and remove the
    • Disconnect wires.
    • To assemble the Washing Machine, follow the same procedure, in the reverse order.
To reassemble your device, Follow these instructions in reverse order.
5 other people completed this guide.
Special thanks to these translators:
pt en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Jose Gustavo Abreu Murta
4,994 Reputation
9 Guides authored
17 Guide Comments
muito boa a espricação
ramiro34676067 - Reply Share
Ola amigos boa noite. Estou como uma maquina de lavar eletrolux lt12f já troquei a placa de potencia e a de interface, agora ela fica com todos os leds ligados e o buzzer bipando sem parar.
Será que os amigos podem ame ajudar a identificar qual o problema?
Anael Dolesk - Reply Share
Anael, reveja todas as conexões e certifique-se que a placa principal é do modelo correto.
Sugiro desconectar os outros cabos e fazer um teste.
Jose Gustavo Abreu Murta - Reply Share
Minha máquina está girando de um lado só,ela não gira para os dois lados, só para o lado esquerdo,já olhei em baixo,tudo,fios as peças,oque pode ser?De resto tudo funciona,
Emanuela Peixoto Bortholo - Reply Share
Emanuela, a placa de circuito é que controla o motor. Portanto essa placa pode estar com defeito.
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 222
All Time: 8,141
