Element GC-1020 Battery Replacement
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: step 1, image 1 of 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: step 2, image 1 of 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: step 3, image 1 of 2 Element GC-1020 Battery  Replacement, Battery: step 3, image 2 of 2
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
2 other people completed this guide.
Lashaun Noel
591 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 448
