Elvie Stride Disassembly
  1. Elvie Stride Disassembly, Elvie Stride: step 1, image 1 of 1
    • Take off the rubber sleeve around the case.
    • The two halves of the clamshell are held together by about 9 plastic snaps - no screws or glue.
    • A handful of guitar picks and gentle prying on each side should be sufficient to pop it open.
  2. Elvie Stride Disassembly: step 2, image 1 of 1
    • Four T6 Torx screws hold a black piece of plastic into the front clamshell.
  3. Elvie Stride Disassembly: step 3, image 1 of 1
    • The battery is held in place by a small bit of adhesive. A spudger and light force is sufficient to remove it.
  4. Elvie Stride Disassembly: step 4, image 1 of 2 Elvie Stride Disassembly: step 4, image 2 of 2
    • The PCB is held into the black plastic bracket with three T6 Torx screws. Remove these, and the device is almost completely disassembled!
    • The battery connector pops vertically out of the socket (not by sliding parallel to the PCB).
  5. Elvie Stride Disassembly: step 5, image 1 of 1
    • We can identify a few key components on the board:
    • Nordic Semi nRF52832 (Bluetooth chip)
    • Winbond 25Q32JV 32MB SPI Flash
    • TI BQ25601 battery charge controller
    • WCH WC340H USB-UART controller
3 other people completed this guide.
Steven Bell
493 Reputation
2 Guides authored
9 Comments
my battery keeps disconnecting inside the hub, not sure how to fix it but that could be a common issue with them.
Angela Darby - Reply
I didn't have a guitar pick on hand but was able to use an old gift card to open this up. Any credit card would work here.
Randall Ary - Reply
what battery is used? is it a common size one can buy easily, with a standard connector?
Gregory Fung - Reply
It's a standard 18500 li-ion cell, nominally 2300mAh. I can't identify the connector but it looks similar to a Molex Pico-EZmate.
The connector is shrink-wrapped onto the battery, and could probably be removed and taped onto a new one.
Steven Bell -
The battery connector definitely comes away too easily from the board. If my wife's does it again, I'm thinking I'll see about using a dab of hot glue to see it down. It could damage it but only one way to find out. @angeladarby
Good luck
jwachendorf - Reply
Past 24 Hours: 13
Past 7 Days: 91
Past 30 Days: 234
All Time: 8,316
