Ematic FunTab 3 Camera Replacement
  1. Ematic FunTab 3 Camera Replacement, Back Panel: step 1, image 1 of 3 Ematic FunTab 3 Camera Replacement, Back Panel: step 1, image 2 of 3 Ematic FunTab 3 Camera Replacement, Back Panel: step 1, image 3 of 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Camera Replacement: step 2, image 1 of 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Camera Replacement, Camera: step 3, image 1 of 2 Ematic FunTab 3 Camera Replacement, Camera: step 3, image 2 of 2
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Camera Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to flip up the black retaining tab.
  5. Ematic FunTab 3 Camera Replacement: step 5, image 1 of 2 Ematic FunTab 3 Camera Replacement: step 5, image 2 of 2
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Amanda Davis
581 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 239
