Ematic Genesis 2 Audio Jack Repair
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: step 1, image 1 of 2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: step 1, image 2 of 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: step 2, image 1 of 3 Ematic Genesis 2 Audio Jack Repair: step 2, image 2 of 3 Ematic Genesis 2 Audio Jack Repair: step 2, image 3 of 3
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: step 3, image 1 of 1
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 164
