Ematic Genesis 2 Charging Port Replacement
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: step 1, image 1 of 2 Ematic Genesis 2 Charging Port Replacement, Charging Port: step 1, image 2 of 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: step 2, image 1 of 3 Ematic Genesis 2 Charging Port Replacement: step 2, image 2 of 3 Ematic Genesis 2 Charging Port Replacement: step 2, image 3 of 3
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: step 3, image 1 of 2 Ematic Genesis 2 Charging Port Replacement: step 3, image 2 of 2
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: step 4, image 1 of 2 Ematic Genesis 2 Charging Port Replacement: step 4, image 2 of 2
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: step 5, image 1 of 2 Ematic Genesis 2 Charging Port Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: step 6, image 1 of 1
    • Solder replacement port into place.
    • Make sure all connections match original.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 560
