Ematic Genesis 2 Screen Replacement
  1. Ematic Genesis 2 Screen Replacement, Screen: step 1, image 1 of 2 Ematic Genesis 2 Screen Replacement, Screen: step 1, image 2 of 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: step 2, image 1 of 3 Ematic Genesis 2 Screen Replacement: step 2, image 2 of 3 Ematic Genesis 2 Screen Replacement: step 2, image 3 of 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: step 3, image 1 of 2 Ematic Genesis 2 Screen Replacement: step 3, image 2 of 2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: step 4, image 1 of 1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: step 5, image 1 of 1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 451
