Emerson EM744 Battery Replacement
  1. Emerson EM744 Battery  Replacement, Back Plate: step 1, image 1 of 1
    • Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
  2. Emerson EM744 Battery  Replacement: step 2, image 1 of 3 Emerson EM744 Battery  Replacement: step 2, image 2 of 3 Emerson EM744 Battery  Replacement: step 2, image 3 of 3
    • Insert the nylon spudger into the bottom of the tablet, and gently slide it up the side.
    • Pull apart the two sides of the tablet, exposing the circuit board, battery, and other components of the tablet.
  3. Emerson EM744 Battery  Replacement, Battery: step 3, image 1 of 3 Emerson EM744 Battery  Replacement, Battery: step 3, image 2 of 3 Emerson EM744 Battery  Replacement, Battery: step 3, image 3 of 3
    Tool used on this step:
    Buy
  4. Emerson EM744 Battery  Replacement: step 4, image 1 of 1
    • Desolder the positive (red) wire to the positive (+) lead, followed by desoldering the negative (black) wire to the negative lead.
    • Refer to the soldering technique guide.
Akinola
165 Reputation
1 Guide authored
USF Tampa, Team 2-5, Blackwell Fall 2016 Member of USF Tampa, Team 2-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G5
4 Members
12 Guides authored
1 Guide Comment
where can i find the battery replacement for the emerson model em744
tjbblitch - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,350
