Emerson EM744 Camera Replacement
  1. Emerson EM744 Camera Replacement, Back Plate: step 1, image 1 of 1
    • Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
  2. Emerson EM744 Camera Replacement: step 2, image 1 of 3 Emerson EM744 Camera Replacement: step 2, image 2 of 3 Emerson EM744 Camera Replacement: step 2, image 3 of 3
    • Insert the nylon spudger into the bottom of the tablet, and gently slide it up the side.
    • Pull apart the two sides of the tablet, exposing the circuit board, battery, and other components of the tablet.
  3. Emerson EM744 Camera Replacement, Camera: step 3, image 1 of 2 Emerson EM744 Camera Replacement, Camera: step 3, image 2 of 2
    • Using the spudger to raise the zero insertion force (ZIF) connector to freely release the ribbon.
  4. Emerson EM744 Camera Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers gently pull the ribbon off of the enclosure.
    • Remove the camera.
Micalle Marin
267 Reputation
2 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2016 Member of USF Tampa, Team 2-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G5
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 312
