Ena Micro 9 grindstone replacement
  1. Ena Micro 9 grindstone replacement, Jura ENA micro 9 opening procedure: step 1, image 1 of 1
    • Pull out the power plug!
    • Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
    • Remove all coffee beans.
  2. Ena Micro 9 grindstone replacement, Top covers: step 2, image 1 of 2 Ena Micro 9 grindstone replacement, Top covers: step 2, image 2 of 2
    • The top covers do not necessarily have to be removed for all repairs. However, it is indispensable for thorough cleaning. It may be easier to loosen the top covers if the side panels are removed first. The process is somewhat tricky.
    • Pry the central ventilation cover up.
  3. Ena Micro 9 grindstone replacement: step 3, image 1 of 3 Ena Micro 9 grindstone replacement: step 3, image 2 of 3 Ena Micro 9 grindstone replacement: step 3, image 3 of 3
    • Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
    • If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
  4. Ena Micro 9 grindstone replacement: step 4, image 1 of 2 Ena Micro 9 grindstone replacement: step 4, image 2 of 2
    • Flip up the front cover.
    • Remove the cover. In the model with the side holes, you can pull them out at an angle to the front. With the other model, you have to push it back a little to unhook it, then lift it up.
  5. Ena Micro 9 grindstone replacement: step 5, image 1 of 1
    • This is what it looks like when the two lids are gone. A lot of dirt built up.
  6. Ena Micro 9 grindstone replacement, Side panels: step 6, image 1 of 1
    • The side parts are pushed out to the rear. However, they are secured with two screws and a lock at the top and a wedge-shaped catch on the sides.
    • Unscrew the two T15 Torx screws that secure the side panels at the top.
  7. Ena Micro 9 grindstone replacement: step 7, image 1 of 3 Ena Micro 9 grindstone replacement: step 7, image 2 of 3 Ena Micro 9 grindstone replacement: step 7, image 3 of 3
    • The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
    • Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
    • Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
  8. Ena Micro 9 grindstone replacement: step 8, image 1 of 3 Ena Micro 9 grindstone replacement: step 8, image 2 of 3 Ena Micro 9 grindstone replacement: step 8, image 3 of 3
    • This is what it looks like underneath. The lock is secured with an oval head screw. It looks like a rivet. To open you need a special oval head bit, in an emergency you can use pliers.
    • Remove the oval head screw.
    • Push the lock firmly upwards as far as possible.
  9. Ena Micro 9 grindstone replacement: step 9, image 1 of 1
    • The side parts are held at the top and bottom with three hooks each. Therefore, they have to be moved backwards to detach them. However, they are secured against shifting with wedge-shaped notches at the front. The next step shows how they can be solved.
    • The notches must be lifted out of the openings. They are located on both sides at the top and bottom about 1.5 cm from the edge and 7 cm from the front edge.
    • This is what the wedge-shaped notches look like
  10. Ena Micro 9 grindstone replacement: step 10, image 1 of 3 Ena Micro 9 grindstone replacement: step 10, image 2 of 3 Ena Micro 9 grindstone replacement: step 10, image 3 of 3
    • Lay the machine on its side.
    • Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
    • Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
    • Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
    • In the same way, insert another opening pick on the opposite edge.
    • Now both notches are free and the side part can be moved in the next step.
  11. Ena Micro 9 grindstone replacement: step 11, image 1 of 1
    • Push the side panel firmly backwards. It may get stuck a bit and you need to use a plastic pry tool to help.
    • Take off the side panel and set it aside.
    • Repeat for the other side panel.
  12. Ena Micro 9 grindstone replacement: step 12, image 1 of 3 Ena Micro 9 grindstone replacement: step 12, image 2 of 3 Ena Micro 9 grindstone replacement: step 12, image 3 of 3
    • Release the catches on the top of the inner cover.
    • Flip the inner cover down and lift it out. The brew group becomes now visible.
    • The third picture shows a view of the other side.
  13. Ena Micro 9 grindstone replacement, Top cover: step 13, image 1 of 1
    • Remove the three Torx T15 screws that secure the top cover.
    • Carefully remove the top cover. Start at the back. The top cover is stuck quite tightly under the front cover, carefully remove it bit by bit.
  14. Ena Micro 9 grindstone replacement, Grindstones: step 14, image 1 of 3 Ena Micro 9 grindstone replacement, Grindstones: step 14, image 2 of 3 Ena Micro 9 grindstone replacement, Grindstones: step 14, image 3 of 3
    • The grinder is now open.
    • Pull off the red plastic clip on the grind adjuster.
    • Lift out the grinder adjuster.
    • When reassembling, make sure that the deflection lever for actuating the white microswitch is inserted correctly. (Already removed in the picture). The axle is marked in red.
  15. Ena Micro 9 grindstone replacement: step 15, image 1 of 2 Ena Micro 9 grindstone replacement: step 15, image 2 of 2
    • Basically, the grindstones are replaced in the same way as with other Jura grinders, use these instructions.
    • Be sure to follow the instructions in the next step before you buy the grindstones!
  16. Ena Micro 9 grindstone replacement: step 16, image 1 of 2 Ena Micro 9 grindstone replacement: step 16, image 2 of 2
    • Different grinders are used in the ENA models. The grindstones must be replaced with the same type. It is better to remove the grindstones beforehand and compare them before buying new ones.
    • The first picture shows the grindstones for the Aroma Plus grinder. An indication of this is that the grinding process only takes about 3 seconds. A groove is clearly visible on the upper edge of the grinding ring. The grinder has a slightly different design, the slip clutch with springs and balls under the grinding cone is missing.
    • The second picture shows the conventional model. The grinding ring has no groove. The grinding process takes about 6 seconds.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,879 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 48
All Time: 318
