Ender 3 / CR20/PRO Y axis Linear rail kit install
AJ Pereira
AJ Pereira and one other contributor
Last updated on March 1, 2023
No estimate
Moderate
Bullets!
Community-Contributed Guide
  1. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: step 1, image 1 of 2 Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: step 1, image 2 of 2
    • Remove all 4 bed leveling screws for the Bed heater.
    • Lift the bed heater and set it behind or to the left of the printer
  2. Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: step 2, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: step 2, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Teardown: step 2, image 3 of 3
    • Remove all 4 idler pulley bracket screws
    • Lift pulley bracket to remove tension on the belt
    • Remove Y belt
    • Remove idler pulley bracket and set aside all parts
  3. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage: step 3, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage: step 3, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage: step 3, image 3 of 3
    • Slide off Y carriage of the front of the Y axis extrusion
    • Remove V-Slots wheels
  4. Ender 3 / CR20/PRO Y axis Linear rail kit install, Rail Prep: step 4, image 1 of 2 Ender 3 / CR20/PRO Y axis Linear rail kit install, Rail Prep: step 4, image 2 of 2
    • Remove Linear Rails for packaging and Wipe off excess oil with a lint free cloth
    • Preinstall M3x8 SHCS and Sliding Tnuts
    • Take Note to skip 2 holes between each fastener, and ensure to mirror this process from each end of the rail until you overlap in the middle
  5. Ender 3 / CR20/PRO Y axis Linear rail kit install, Slide On & Mount Rails: step 5, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Slide On & Mount Rails: step 5, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Slide On & Mount Rails: step 5, image 3 of 3
    • Note Sliding in the Linear rails do not allow rail block to slide off the end of the rails.
    • Insert Printed T-nut guide to help with sliding the rail into the top slot on the Y axis extrusion
    • Slide the rails into the top T-slot
    • Aline rails with the end of the extrusion using one of the included stiffener plates as a stop
  6. Ender 3 / CR20/PRO Y axis Linear rail kit install, Mount Rails: step 6, image 1 of 2 Ender 3 / CR20/PRO Y axis Linear rail kit install, Mount Rails: step 6, image 2 of 2
    • Note when sliding on Rail alignment Jigs do not allow Linear rail block to slide off the end of the rails.
    • Tighten the M3 mounting bolts to the front of the rail to the back on both sides
  7. Ender 3 / CR20/PRO Y axis Linear rail kit install, Ender 3 / CR20-PRO 5th Hole: step 7, image 1 of 2 Ender 3 / CR20/PRO Y axis Linear rail kit install, Ender 3 / CR20-PRO 5th Hole: step 7, image 2 of 2
    • Linear rail Block mounting hardware Per rail block mounting hole
    • M3x12 SHCS
    • M3 Flat Washer Per hole
    • Split lock washer
    • Stiffener plate 5th hole Screw (M3x10 SHCS with M3 washer)
    • M3 Hex nut
  8. Ender 3 / CR20/PRO Y axis Linear rail kit install, Mounting Rail Carriage Adaptors: step 8, image 1 of 2 Ender 3 / CR20/PRO Y axis Linear rail kit install, Mounting Rail Carriage Adaptors: step 8, image 2 of 2
    • Right side
    • Left side
  9. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage Install: step 9, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage Install: step 9, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Carriage Install: step 9, image 3 of 3
    • M4x10 FHCS
    • M4x12 BHCS
    • M4 washer
    • M4 washer large OD
    • M4 FHCS screw first. Then attach the M4x14S BHCS screw with the washer Stack.
    • Slide the Y Carriage forward and check that Y Carriage is parallel to that front of the Y extrusion. Then tight the screws fully.
  10. Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Endstop Spacer: step 10, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Endstop Spacer: step 10, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Y Endstop Spacer: step 10, image 3 of 3
    • Install this spacer between the Endstop bracket extrusion
    • Check that the y endstop is triggered by the Adaptor plate
  11. Ender 3 / CR20/PRO Y axis Linear rail kit install, Belt Re-install: step 11, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Belt Re-install: step 11, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Belt Re-install: step 11, image 3 of 3
    • Re-install idler pulley bracket
    • Re-install Belt back into the tab slots
    • Pulley idler pulley bracket forward to tighten the belt.
    • Then tighten mounting screws on both sides
  12. Ender 3 / CR20/PRO Y axis Linear rail kit install, Reinstall Bed Plate: step 12, image 1 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Reinstall Bed Plate: step 12, image 2 of 3 Ender 3 / CR20/PRO Y axis Linear rail kit install, Reinstall Bed Plate: step 12, image 3 of 3
    • CR20 Pro
    • Reinstall: bed heater plate, Solid bed mounts, Nylock nuts or bed leveling knobs
    • Ender 3 and CR20
    • Reinstall: bed heater plate, bed leveling springs and bed leveling knobs
Finish Line
AJ Pereira
2,707 Reputation
16 Guides authored
Tiny Machines 3D Member of Tiny Machines 3D
Community
5 Members
41 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 48
All Time: 2,587
