Introduction
Applicable to all engines (H4D and H4Bt).
Replace every: 20,000km or year. It should be replaced earlier if driving in dusty environments.
A clogged engine air filter may impact fuel economy: it will create more resistance and therefore, increase the pumping losses.
Note: recommendations are given according to the French RTA's (Revue Technique Automobile) maintenance plan, matching Smart 453's maintenance plan in this case.
Unscrew the 6 T50 screws by hand or using a wrench and a socket.
Lift and set aside the engine hood.
Unscrew the 2 Torx T25 screws.
Disglog the air filter lig by slightly pushing/pulling it forward then lifting it.
Extract the used air filter.
Dust off the air box from any debris residing in it.
Install the new air filter.
Replace the lid by sliding the two notches.
Screw back the two T25 Torx screws while maintaining a slight pression on the lid.
Congratulations ! You replaced your engine air filter
6 other people completed this guide.
Special thanks to these translators:
100%
AntonioTwingo is helping us fix the world! Want to contribute?
Start translating ›
