Thrustmaster T3PM Maintenance
  1. Thrustmaster T3PM Maintenance, Disconnect the pedal heads: step 1, image 1 of 2 Thrustmaster T3PM Maintenance, Disconnect the pedal heads: step 1, image 2 of 2
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
    • Before starting, unplug your T3PM.
  2. Thrustmaster T3PM Maintenance, Remove screws from the bottom: step 2, image 1 of 1
    • Using Phillips screwdriver remove all screws at the bottom.
  3. Thrustmaster T3PM Maintenance, Remove the top cover: step 3, image 1 of 1
    • Remove the top cover and put it aside
    • Clean off any dust, residue, pet hair and other foreign debris that has accumulated inside the pedal set.
  4. Thrustmaster T3PM Maintenance, Inspect the wires and tape.: step 5, image 1 of 2 Thrustmaster T3PM Maintenance, Inspect the wires and tape.: step 5, image 2 of 2
    • Make sure that the wires and the main cable are secure.
    • Replace sticky tape if necessary.
  5. Thrustmaster T3PM Maintenance, Thoroughly clean each pedal.: step 6, image 1 of 1
    • Clean off any dust, residue, pet hair etc from the pedals themselves, near the sensors and springs.
    • Make sure to clean off the extremities of the pedals.
  6. Thrustmaster T3PM Maintenance, Clean the sensors: step 7, image 1 of 2 Thrustmaster T3PM Maintenance, Clean the sensors: step 7, image 2 of 2
    • Using an air-blower, compressed air-can or other tool, clean the sensors.
    • Be cautions as to not damage the sensors, wires or the connectors.
    • Watch out for Electro-static Discharge. Make sure not to touch the sensors or use anti-static wrist strap.
  7. Thrustmaster T3PM Maintenance, Inspect the springs.: step 8, image 1 of 1
    • Inspect the conditions of the gas and clutch springs.
    • Re-lubricate if necessary.
To reassemble your device, follow the steps 1,2,3 in reverse order.
Formica Fusca
2,600 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 68
All Time: 1,281
