Entry Door Weatherstripping Replacement
  1. Entry Door Weatherstripping Replacement, Weatherstripping: step 1, image 1 of 2 Entry Door Weatherstripping Replacement, Weatherstripping: step 1, image 2 of 2
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: step 2, image 1 of 3 Entry Door Weatherstripping Replacement: step 2, image 2 of 3 Entry Door Weatherstripping Replacement: step 2, image 3 of 3
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: step 3, image 1 of 1
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: step 4, image 1 of 2 Entry Door Weatherstripping Replacement: step 4, image 2 of 2
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: step 5, image 1 of 2 Entry Door Weatherstripping Replacement: step 5, image 2 of 2
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: step 6, image 1 of 3 Entry Door Weatherstripping Replacement: step 6, image 2 of 3 Entry Door Weatherstripping Replacement: step 6, image 3 of 3
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: step 7, image 1 of 1
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: step 8, image 1 of 2 Entry Door Weatherstripping Replacement: step 8, image 2 of 2
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
Agilakumaran Shanmugalingam
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 170
All Time: 8,847
