Envizen V100M Speakers Replacement
  1. Envizen V100M Speakers Replacement, Back Cover: step 1, image 1 of 2 Envizen V100M Speakers Replacement, Back Cover: step 1, image 2 of 2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Speakers Replacement: step 2, image 1 of 3 Envizen V100M Speakers Replacement: step 2, image 2 of 3 Envizen V100M Speakers Replacement: step 2, image 3 of 3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Speakers Replacement, Speakers: step 3, image 1 of 1
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. Envizen V100M Speakers Replacement: step 4, image 1 of 1
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Envizen V100M Speakers Replacement: step 5, image 1 of 1
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
nbach
663 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 119
