Epiphone ES-335 PRO Pickguard Replacement
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: step 1, image 1 of 1
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: step 2, image 1 of 2 Epiphone ES-335 PRO Pickguard Replacement: step 2, image 2 of 2
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
One Comment
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 62
All Time: 4,693
