Epiphone Les Paul Special Input Jack Replacement
  1. Epiphone Les Paul Special Input Jack Replacement, Input Jack: step 1, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the four 7 mm screws holding the input jack cover.
  2. Epiphone Les Paul Special Input Jack Replacement: step 2, image 1 of 1
    • With a 12 mm wrench, remove the nut holding the input jack in place.
  3. Epiphone Les Paul Special Input Jack Replacement: step 3, image 1 of 2 Epiphone Les Paul Special Input Jack Replacement: step 3, image 2 of 2
    • Lift off the tone control knob.
  4. Epiphone Les Paul Special Input Jack Replacement: step 4, image 1 of 1
    • Using an 11 mm wrench, remove the nut of the tone control.
  5. Epiphone Les Paul Special Input Jack Replacement: step 5, image 1 of 1
    • With a Phillips #1 screwdriver, remove the three 7 mm screws holding on the back plate.
  6. Epiphone Les Paul Special Input Jack Replacement: step 6, image 1 of 2 Epiphone Les Paul Special Input Jack Replacement: step 6, image 2 of 2
    • Pull out the tone control.
  7. Epiphone Les Paul Special Input Jack Replacement: step 7, image 1 of 2 Epiphone Les Paul Special Input Jack Replacement: step 7, image 2 of 2
    • Push the input jack through the body and pull it out.
  8. Epiphone Les Paul Special Input Jack Replacement: step 8, image 1 of 1
    • The soldering iron is very hot. Avoid contact with skin, as well as the body of the instrument. When not in use, place it on a soldering iron stand.
    • Desolder the wires from the input jack.
  9. Epiphone Les Paul Special Input Jack Replacement: step 9, image 1 of 1
    • Solder the wires to the input jack.
    • Repeat steps 7-1 in reverse order to put it all back together.
To get everything back into its original place, follow steps 1-7 in reverse order.
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 77
All Time: 4,367
