Epomaker Shadow-X Battery Replacement
  1. Epomaker Shadow-X Battery Replacement, Battery: step 1, image 1 of 3 Epomaker Shadow-X Battery Replacement, Battery: step 1, image 2 of 3 Epomaker Shadow-X Battery Replacement, Battery: step 1, image 3 of 3
    • Power off the Epomaker Shadow-X keyboard.
    • Disconnect any attached cables.
  2. Epomaker Shadow-X Battery Replacement: step 2, image 1 of 2 Epomaker Shadow-X Battery Replacement: step 2, image 2 of 2
    • Use a hex screwdriver to remove all eight screws on the underside of the keyboard.
  3. Epomaker Shadow-X Battery Replacement: step 3, image 1 of 2 Epomaker Shadow-X Battery Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to gently pry open the keyboard case, working your way around each side.
    • Carefully separate the top and bottom covers, being mindful of any connecting cables between the two halves.
  4. Epomaker Shadow-X Battery Replacement: step 4, image 1 of 2 Epomaker Shadow-X Battery Replacement: step 4, image 2 of 2
    • Use your fingernails to gently "walk" the battery connector directly out of its socket.
  5. Epomaker Shadow-X Battery Replacement: step 5, image 1 of 2 Epomaker Shadow-X Battery Replacement: step 5, image 2 of 2
    • Use an opening tool to gently pry the battery out of the chassis.
    • Take care not to bend or puncture the battery.
    • Press the battery into place using any adhesive or mounting tabs provided with the replacement.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 45
All Time: 769
