Epson EX90 Cooling Fan Replacement
  1. Epson EX90 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 2 Epson EX90 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 2
    • Place the projector so that the bottom side is facing upwards
    • Remove the eight screws pictured from the bottom of the device.
    • Open the cover.
    • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
  2. Epson EX90 Cooling Fan Replacement: step 2, image 1 of 1
    • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
    • Take care to record the port which each wire comes from, so as not to get your wires crossed.
  3. Epson EX90 Cooling Fan Replacement: step 3, image 1 of 1
    • Remove the three screws pictured, which hold the fan's frame in place.
  4. Epson EX90 Cooling Fan Replacement: step 4, image 1 of 2 Epson EX90 Cooling Fan Replacement: step 4, image 2 of 2
    • Remove fan and related assembly from projector.
    • Detach fan from housing.
    • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
Lucas Ketchie
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 314
