Epson Home Cinema 2150 Projector Lamp Replacement
  1. Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: step 1, image 1 of 3 Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: step 1, image 2 of 3 Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: step 1, image 3 of 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Projector Lamp Replacement: step 2, image 1 of 3 Epson Home Cinema 2150 Projector Lamp Replacement: step 2, image 2 of 3 Epson Home Cinema 2150 Projector Lamp Replacement: step 2, image 3 of 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Projector Lamp Replacement: step 3, image 1 of 3 Epson Home Cinema 2150 Projector Lamp Replacement: step 3, image 2 of 3 Epson Home Cinema 2150 Projector Lamp Replacement: step 3, image 3 of 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
Luis Garcia
577 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 722
