Epson Home Cinema 2150 Speaker Replacement
  1. Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: step 1, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: step 1, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: step 1, image 3 of 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Speaker Replacement: step 2, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 2, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 2, image 3 of 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Speaker Replacement: step 3, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 3, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 3, image 3 of 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
  4. Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: step 4, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: step 4, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: step 4, image 3 of 3
    • Remove the air filter cover. Grip the piece with two fingers above and below at the center.
    • Grab the air filter from the protruding tab and pull the filter out.
  5. Epson Home Cinema 2150 Speaker Replacement: step 5, image 1 of 2 Epson Home Cinema 2150 Speaker Replacement: step 5, image 2 of 2
    • From the back of the projector remove three 6 mm Phillips #1 screws.
  6. Epson Home Cinema 2150 Speaker Replacement: step 6, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 6, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 6, image 3 of 3
    • From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
    • Remove two 6 mm Phillips #1 screws.
    • Pull off remaining plastic molding.
  7. Epson Home Cinema 2150 Speaker Replacement: step 7, image 1 of 2 Epson Home Cinema 2150 Speaker Replacement: step 7, image 2 of 2
    • From the lamp access slot, remove four 9.5 mm Philips #1 screws
  8. Epson Home Cinema 2150 Speaker Replacement: step 8, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 8, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 8, image 3 of 3
    • From the filter slot, unscrew two 9.5 mm #1 screws.
  9. Epson Home Cinema 2150 Speaker Replacement: step 9, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 9, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 9, image 3 of 3
    • Partially lift the top portion of the device housing.
    • Lifting too far or too hard may damage any cables between the housing and the motherboard.
  10. Epson Home Cinema 2150 Speaker Replacement: step 10, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 10, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 10, image 3 of 3
    • Disconnect the ribbon cable from the motherboard.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of two fingers.
  11. Epson Home Cinema 2150 Speaker Replacement: step 11, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 11, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 11, image 3 of 3
    • Remove three 5 mm Phillips #1 screws.
  12. Epson Home Cinema 2150 Speaker Replacement: step 12, image 1 of 2 Epson Home Cinema 2150 Speaker Replacement: step 12, image 2 of 2
    • Press on the metal connector and firmly pull on the remaining ribbon cable.
  13. Epson Home Cinema 2150 Speaker Replacement: step 13, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 13, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 13, image 3 of 3
    • Pull the clips on the case with two fingers on opposite ends and remove the case.
  14. Epson Home Cinema 2150 Speaker Replacement, Speaker: step 14, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement, Speaker: step 14, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement, Speaker: step 14, image 3 of 3
    • Pull up on the rear panel retaining clip.
    • Pull the rear panel away from the device to remove.
  15. Epson Home Cinema 2150 Speaker Replacement: step 15, image 1 of 2 Epson Home Cinema 2150 Speaker Replacement: step 15, image 2 of 2
    • Disconnect the speaker wire from the motherboard.
    • Pull up at the end of the wire when removing the connector.
  16. Epson Home Cinema 2150 Speaker Replacement: step 16, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 16, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 16, image 3 of 3
    • Unwind the speaker wire through the metal chassis.
  17. Epson Home Cinema 2150 Speaker Replacement: step 17, image 1 of 3 Epson Home Cinema 2150 Speaker Replacement: step 17, image 2 of 3 Epson Home Cinema 2150 Speaker Replacement: step 17, image 3 of 3
    • Remove two 6mm Phillips #1 screws.
    • The speaker will fall out once screws are removed.
Luis Garcia
577 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 117
