Epson Home Cinema 2150 Wireless connection board Replacement
  1. Epson Home Cinema 2150 Wireless connection board Replacement, Projector Lamp: step 1, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement, Projector Lamp: step 1, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement, Projector Lamp: step 1, image 3 of 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Wireless connection board Replacement: step 2, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 2, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 2, image 3 of 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Wireless connection board Replacement: step 3, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 3, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 3, image 3 of 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
  4. Epson Home Cinema 2150 Wireless connection board Replacement, Wireless connection board: step 4, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement, Wireless connection board: step 4, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement, Wireless connection board: step 4, image 3 of 3
    • Remove the air filter cover. Grip the piece with two fingers above and below at the center.
    • Grab the air filter from the protruding tab and pull the filter out.
  5. Epson Home Cinema 2150 Wireless connection board Replacement: step 5, image 1 of 2 Epson Home Cinema 2150 Wireless connection board Replacement: step 5, image 2 of 2
    • From the back of the projector remove three 6 mm Phillips #1 screws.
  6. Epson Home Cinema 2150 Wireless connection board Replacement: step 6, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 6, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 6, image 3 of 3
    • From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
    • Remove two 6 mm Phillips #1 screws.
    • Pull off remaining plastic molding.
  7. Epson Home Cinema 2150 Wireless connection board Replacement: step 7, image 1 of 2 Epson Home Cinema 2150 Wireless connection board Replacement: step 7, image 2 of 2
    • From the lamp access slot, remove four 9.5 mm Philips #1 screws
  8. Epson Home Cinema 2150 Wireless connection board Replacement: step 8, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 8, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 8, image 3 of 3
    • From the filter slot, unscrew two 9.5 mm #1 screws.
  9. Epson Home Cinema 2150 Wireless connection board Replacement: step 9, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 9, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 9, image 3 of 3
    • Partially lift the top portion of the device housing.
    • Lifting too far or too hard may damage any cables between the housing and the motherboard.
  10. Epson Home Cinema 2150 Wireless connection board Replacement: step 10, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 10, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 10, image 3 of 3
    • Disconnect the ribbon cable from the motherboard.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of two fingers.
  11. Epson Home Cinema 2150 Wireless connection board Replacement: step 11, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 11, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 11, image 3 of 3
    • Remove three 5 mm Phillips #1 screws.
  12. Epson Home Cinema 2150 Wireless connection board Replacement: step 12, image 1 of 2 Epson Home Cinema 2150 Wireless connection board Replacement: step 12, image 2 of 2
    • Press on the metal connector and firmly pull on the remaining ribbon cable.
  13. Epson Home Cinema 2150 Wireless connection board Replacement: step 13, image 1 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 13, image 2 of 3 Epson Home Cinema 2150 Wireless connection board Replacement: step 13, image 3 of 3
    • Pull the clips on the case with two fingers on opposite ends and remove the case.
Luis Garcia
577 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 210
