Epson PowerLite 822 Plus Lamp Replacement
  1. Epson PowerLite 822 Plus Lamp Replacement, Lamp: step 1, image 1 of 1
    • If you just used the projector you will want to let it sit for about an hour to cool off.
    • If you have not used the projector within the past few hours you are ready to get to work.
  2. Epson PowerLite 822 Plus Lamp Replacement: step 2, image 1 of 2 Epson PowerLite 822 Plus Lamp Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the 6 mm screw that holds the lamp cover in place.
  3. Epson PowerLite 822 Plus Lamp Replacement: step 3, image 1 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 3, image 2 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 3, image 3 of 3
    • Apply pressure to the lamp cover, pulling it towards the end of the projector.
    • Pop the lamp cover off, exposing the lamp.
  4. Epson PowerLite 822 Plus Lamp Replacement: step 4, image 1 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 4, image 2 of 3 Epson PowerLite 822 Plus Lamp Replacement: step 4, image 3 of 3
    • There are two 9mm screws which have already been loosened. These screws do not come all the way out.
    • Grip the finger hold and pull it straight out of the projector.
  5. Epson PowerLite 822 Plus Lamp Replacement: step 5, image 1 of 1
    • After pulling it straight up by the finger hold the lamp will be revealed and ready to be replaced.
Emma Richey
915 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 121
