Epson PowerLite 83+ Motherboard Replacement
Introduction
Go to step 1If you need to replace the motherboard of your Epson PowerLite 83+, this guide will take you through the steps.
A faulty motherboard may cause ports to cease functioning, the device to not power on, or other issues preventing use of the projector. Cleaning the motherboard and checking the connections may remedy issues. If that doesn't work, you may need to purchase a new one and replace it.
Before beginning this guide, be sure to power off the device and unplug from the power adapter.
Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
Lift the motherboard from the front side of the projector to clear the ribbon cables.
Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
Remove the motherboard from the case.
