Epson Powerlite 410W Lamp Replacement
  1. Epson Powerlite 410W Lamp Replacement, Lamp: step 1, image 1 of 1
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
  2. Epson Powerlite 410W Lamp Replacement: step 2, image 1 of 3 Epson Powerlite 410W Lamp Replacement: step 2, image 2 of 3 Epson Powerlite 410W Lamp Replacement: step 2, image 3 of 3
    • Loosen the single captive screw holding the lamp cover in place using a Phillips #2 screwdriver.
    • Slide the cover out, then lift it off and place to the side.
  3. Epson Powerlite 410W Lamp Replacement: step 3, image 1 of 1
    • Loosen the two captive screws that hold the lamp in place using a Phillips #2 screwdriver.
  4. Epson Powerlite 410W Lamp Replacement: step 4, image 1 of 1
    • Use your hands to pull the lamp straight out of the projector.
    • When inserting the new lamp, push the lamp down firmly, where the label “PUSH” appears.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 469
