Epson Powerlite S5 Projection Lamp Replacement
  1. Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: step 1, image 1 of 2 Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: step 1, image 2 of 2
    • Make sure the power is off before beginning.
    • Unplug the projector's power cord from the wall.
    • Allow the projection lamp to cool completely before replacing.
  2. Epson Powerlite S5 Projection Lamp Replacement: step 2, image 1 of 2 Epson Powerlite S5 Projection Lamp Replacement: step 2, image 2 of 2
    • Using a Phillip's head screwdriver, remove the screw from the back.
  3. Epson Powerlite S5 Projection Lamp Replacement: step 3, image 1 of 3 Epson Powerlite S5 Projection Lamp Replacement: step 3, image 2 of 3 Epson Powerlite S5 Projection Lamp Replacement: step 3, image 3 of 3
    • Slide the cover back.
    • Lift cover to remove.
  4. Epson Powerlite S5 Projection Lamp Replacement: step 4, image 1 of 3 Epson Powerlite S5 Projection Lamp Replacement: step 4, image 2 of 3 Epson Powerlite S5 Projection Lamp Replacement: step 4, image 3 of 3
    • Locate the two screws on either side of the projection lamp.
    • Using a Phillip's head screwdriver, loosen the two screws.
    • The screws only loosen. You don't have to worry about them falling out.
  5. Epson Powerlite S5 Projection Lamp Replacement: step 5, image 1 of 3 Epson Powerlite S5 Projection Lamp Replacement: step 5, image 2 of 3 Epson Powerlite S5 Projection Lamp Replacement: step 5, image 3 of 3
    • Grip the two plastic bars on the top of the old projection lamp.
    • Remove the projection lamp by pulling straight up.
    • If there is any lamp breakage, handle the shards carefully to avoid injury.
Greg Brown
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,385
