Epson VS250 Lamp Replacement
  1. Epson VS250 Lamp Replacement, Lamp: step 1, image 1 of 1
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Use Phillips #1 screwdriver to loosen the 10 mm screw on the top right corner of the projector.
    • The screw does not need to come all the way out.
  2. Epson VS250 Lamp Replacement: step 2, image 1 of 1
    • Slide the cover to the right and lift the cover up and out to remove.
  3. Epson VS250 Lamp Replacement: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to loosen the two 10 mm screws that hold the lamp in place.
    • The two 10 mm screws do not need to come all the way out. Just ensure they are loose.
  4. Epson VS250 Lamp Replacement: step 4, image 1 of 2 Epson VS250 Lamp Replacement: step 4, image 2 of 2
    • After loosening both screws, remove the lamp from the projector by pulling it up and out.
Warren Cutlip
604 Reputation
5 Guides authored
Clemson, Team 4-2, Hunter Fall 2021 Member of Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 722
