Equity Alarm Clock 13014 Alarm Switch Replacement
  1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: step 1, image 1 of 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: step 1, image 2 of 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: step 1, image 3 of 3
    • Remove the battery door using your finger nail or an opening tool.
  2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: step 2, image 1 of 2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
  3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: step 3, image 1 of 1
    • Remove the back cover gently.
    • DO NOT pull the back cover off quickly or you may damage the wires connected.
  4. Equity Alarm Clock 13014 Alarm Switch Replacement: step 4, image 1 of 2 Equity Alarm Clock 13014 Alarm Switch Replacement: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
    • Remove the small screw located below the alarm switch as well.
  5. Equity Alarm Clock 13014 Alarm Switch Replacement: step 5, image 1 of 2 Equity Alarm Clock 13014 Alarm Switch Replacement: step 5, image 2 of 2
    • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
    • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
    • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
    • Use a Phillips #1 screwdriver to reinstall the switch screws.
    • Follow steps in reverse order to assemble the clock.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 1,161
