Etekcity Lasergrip 1080 Button Replacement
  1. Etekcity Lasergrip 1080 Button Replacement, Battery: step 1, image 1 of 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Button Replacement: step 2, image 1 of 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Button Replacement: step 3, image 1 of 2 Etekcity Lasergrip 1080 Button Replacement: step 3, image 2 of 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Button Replacement, Buttons: step 4, image 1 of 2 Etekcity Lasergrip 1080 Button Replacement, Buttons: step 4, image 2 of 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Button Replacement: step 5, image 1 of 2 Etekcity Lasergrip 1080 Button Replacement: step 5, image 2 of 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Button Replacement: step 6, image 1 of 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Button Replacement: step 7, image 1 of 2 Etekcity Lasergrip 1080 Button Replacement: step 7, image 2 of 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Button Replacement: step 8, image 1 of 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
Patrick Crawford
741 Reputation
6 Guides authored
USF Tampa, Team 5-1, Blackwell Fall 2015 Member of USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 488
