Eton Soulra XL Woofer Wire Repair
  1. Eton Soulra XL Woofer Wire Repair, Eton Soulra XL Woofer Wire Repair: step 1, image 1 of 1
    • Gently pull down and out on the front cover; it should come off easily.
    • This step is not necessary; if the cover does not come off easily it can be left on.
  2. Eton Soulra XL Woofer Wire Repair: step 2, image 1 of 1
    • Remove two screws from each side using a H2.5 hexagonal screwdriver.
  3. Eton Soulra XL Woofer Wire Repair: step 3, image 1 of 1
    • Pry off "Eton" logo from the side speaker covers using a pry tool.
    • Be careful not to break the emblem when removing.
  4. Eton Soulra XL Woofer Wire Repair: step 4, image 1 of 1
    • Remove the two screws that were covered by the "Eton" logo using a PH0 screwdriver.
  5. Eton Soulra XL Woofer Wire Repair: step 5, image 1 of 1
    • The side speaker covers should come off easily now; remove them.
  6. Eton Soulra XL Woofer Wire Repair: step 6, image 1 of 1
    • Remove the five screws on the underside of the device using a PH0 screwdriver.
  7. Eton Soulra XL Woofer Wire Repair: step 7, image 1 of 1
    • Extend the solar panel into the upright position to access the screws on the backside of the device.
  8. Eton Soulra XL Woofer Wire Repair: step 8, image 1 of 1
    • Remove the three screws at the top of the back panel using H2.5 hexagonal screwdriver.
  9. Eton Soulra XL Woofer Wire Repair: step 9, image 1 of 1
    • Remove the ten screws on the backside of the device using a long-neck PH0 screwdriver.
    • Some of the screws are deep within the panel and require an appropriate (long neck PH0) screwdriver to access them.
  10. Eton Soulra XL Woofer Wire Repair: step 10, image 1 of 1
    • At this point, the back panel of the device should lift off easily. Lift it off and set aside.
  11. Eton Soulra XL Woofer Wire Repair: step 11, image 1 of 1
    • Use compressed air to clear away any dust or debris.
  12. Eton Soulra XL Woofer Wire Repair: step 12, image 1 of 1
    • Inspect wires and locate any speaker loose connections.
  13. Eton Soulra XL Woofer Wire Repair: step 13, image 1 of 1
    • Solder loose wires back into place.
    • Use the methods outlined in the ifixit soldering guide (link in the introduction).
2 other people completed this guide.
Nate Kilmer
128 Reputation
1 Guide authored
One Comment
Awesome instruction. I have this model and the 30 pin dock stopped working. Any chance that you might have instruction to get to the dock and check ribbon? From looking at Bose dock videos, this is a common problem. Namaste, Nathan in Canada.
renaldo71 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 358
