Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement
  1. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: step 1, image 1 of 2 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Brush Roll: step 1, image 2 of 2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: step 3, image 1 of 2 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: step 3, image 2 of 2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: step 4, image 1 of 1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: step 5, image 1 of 1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement: step 6, image 1 of 1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
  7. Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: step 7, image 1 of 3 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: step 7, image 2 of 3 Eureka AirSpeed Bagless Zuum Vacuum Belt Replacement, Belt: step 7, image 3 of 3
    • Remove the belt from around the motor.
8 other people completed this guide.
Celina Burchett
1,122 Reputation
8 Guides authored
Clemson, Team 2-2, Benson Fall 2014 Member of Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Members
18 Guides authored
5 Comments
It was Too hard So went to stretch the belt then it was on
missouri river production - Reply
To reassemble was not available for me so I kind of did it myself but I'm having trouble getting it back on straight
eternallight6 - Reply
i have read every sticker on this vbacuum read several maintenance steps …. i mean DA remove four screws …huh.
now can someone tell me whart size belt to get from the store
Sara Leinen
sparkplugkitten@msn.com
Sara Leinen - Reply
I got it used. I turned it on it worked. Then it just turned off and want come back on some please help me
nickietucker81 - Reply
Where's the trouble shooting
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 42
All Time: 48,153
