Explorer One HD Wifi Camera Battery Replacement
  1. Explorer One HD Wifi Camera Battery Replacement, Battery: step 1, image 1 of 1
    • Position the camera with the bottom panel facing up
  2. Explorer One HD Wifi Camera Battery Replacement: step 2, image 1 of 1
    • Use the 000 size Philips screw head
  3. Explorer One HD Wifi Camera Battery Replacement: step 3, image 1 of 1
    • Carefully unscrew the panel
  4. Explorer One HD Wifi Camera Battery Replacement: step 4, image 1 of 1
    • If you need, use the flathead driver to pry off the cover.
    • If not, simply pull off the panel
  5. Explorer One HD Wifi Camera Battery Replacement: step 5, image 1 of 1
    • Once the battery is exposed, simply pull the battery out.
    • You may have to wiggle the battery to pull it out.
  6. Explorer One HD Wifi Camera Battery Replacement: step 6, image 1 of 1
    • The battery is connected the camera by terminals for ease of removal
    • Be sure to keep the battery and camera clean during this step
  7. Explorer One HD Wifi Camera Battery Replacement: step 7, image 1 of 1
    • push the battery back into the housing gently
Now, your camera is as good as new, have fun!
3 other people completed this guide.
Cameron Smith
400 Reputation
2 Guides authored
Colorado Fixers Member of Colorado Fixers
Community
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 703
