FDHD Floppy drive Disassembly
  1. FDHD Floppy drive Disassembly, Step 1 pull off the springs: step 1, image 1 of 1
    • It’s best to pull Down and twist to pull the spring off
  2. FDHD Floppy drive Disassembly, Pull the other spring off: step 2, image 1 of 1
    • Once again pull and twist movement
  3. FDHD Floppy drive Disassembly, Move this black tab off: step 3, image 1 of 1
    • lift up on the really tiny tab with a flat blade screwdriver and slide it off
    • Push Down
    • It may seem a little bit tricky at first but only push the ejection lever about halfway in
  4. FDHD Floppy drive Disassembly, Unscrew motor: step 6, image 1 of 1
    • Remove these two screws and lift off the motor
    • Note: I did not have the second screw.
  5. FDHD Floppy drive Disassembly, Lift off motor: step 7, image 1 of 1
    • Unplug the motors 3-pin connector to make it easier
  6. FDHD Floppy drive Disassembly, Take off the tiny black washers: step 8, image 1 of 1
    • Insert wisdom here.
    • Thank you for using my guide just clean any places where metal touches metal and reassemble
Thomas
433 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 153
