FLSUN QQ Print Surface Replacement
  1. FLSUN QQ Print Surface Replacement, Heat the bed to 70º F: step 1, image 1 of 3 FLSUN QQ Print Surface Replacement, Heat the bed to 70º F: step 1, image 2 of 3 FLSUN QQ Print Surface Replacement, Heat the bed to 70º F: step 1, image 3 of 3
    • Power up printer
    • Tap Tools
    • Tap Heat
    • Tap Extrude 1 to switch to Bed
    • Tap + till the bed temp is set to 70º
  2. FLSUN QQ Print Surface Replacement, Wait for the bed to reach temp: step 2, image 1 of 1
    • Heating the bed will melt the adhesive and make removing the old print surface much easier
  3. FLSUN QQ Print Surface Replacement, Peel up Old Print Bed: step 3, image 1 of 3 FLSUN QQ Print Surface Replacement, Peel up Old Print Bed: step 3, image 2 of 3 FLSUN QQ Print Surface Replacement, Peel up Old Print Bed: step 3, image 3 of 3
    • Use the putty knife to start peeling up the old bed.
    • Once you get the edge started you should be able to peel the rest by hand.
  4. FLSUN QQ Print Surface Replacement, Remove auto level wire: step 4, image 1 of 1
    • One side of the bed will have a wire taped in with the conductive sticker.
    • If you have upgraded to the leveling switch you can cut this wire.
    • If not, you could carefully peel the wire off of the conductive sticker to save it for later...
    • Without the leveling switch there are various techniques to do conductive leveling.
    • aluminum foil stuck to top of bed and connected to leveling wire
    • homemade leveling switch
    • etc.
    • Power down the printer
    • Use mineral spirits, gloves, and cotton balls to clean the bed
    • Leave the steel plate and magnetic sticker together.
    • Remove the backing from the magnetic sticker.
    • Be sure to align the plate exactly how you want it. Once the sticker is applied it is very difficult to remove and repositioning is not recommended.
    • Carefully apply the sticker and plate from one edge to the other.
  5. FLSUN QQ Print Surface Replacement, Level and Z-Offset: step 7, image 1 of 1
    • If you have upgraded to the leveling switch this step will be easy.
    • Attach Leveling Switch
    • Heat Bed to Normal Printing Temperature
    • Tap Tools
    • Tap Leveling
    • Tap Level
    • Do not forget to adjust Z-Offset
  6. FLSUN QQ Print Surface Replacement, Print Something: step 8, image 1 of 1
    • Watch the first layer go down smoother than ever.
  7. FLSUN QQ Print Surface Replacement, Remove the Print with Ease: step 9, image 1 of 2 FLSUN QQ Print Surface Replacement, Remove the Print with Ease: step 9, image 2 of 2
    • Peel spring steel plate off of magnetic sticker.
    • Flex plate gently to detach print.
    • Retrieve print (I dropped the first one)
You have successfully upgrade the print surface of your FLSUN-QQ
Print Happy
Daniel Green
1,014 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,612
