Factory Reset, Fix Android Problems with Sony PC Companion
Video Overview
  1. Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: step 1, image 1 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: step 1, image 2 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion, Factory Reset, Fix Android Problems  with Sony PC Companion: step 1, image 3 of 3
  2. Factory Reset, Fix Android Problems  with Sony PC Companion: step 2, image 1 of 2 Factory Reset, Fix Android Problems  with Sony PC Companion: step 2, image 2 of 2
    • Install Sony PC Companion in your PC.
  3. Factory Reset, Fix Android Problems  with Sony PC Companion: step 3, image 1 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 3, image 2 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 3, image 3 of 3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
  4. Factory Reset, Fix Android Problems  with Sony PC Companion: step 4, image 1 of 2 Factory Reset, Fix Android Problems  with Sony PC Companion: step 4, image 2 of 2
    • PC Companion will download some files to prepare your PC for software update.
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  5. Factory Reset, Fix Android Problems  with Sony PC Companion: step 5, image 1 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 5, image 2 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 5, image 3 of 3
    • Select the model of your phone.
    • You should not confuse the model.
  6. Factory Reset, Fix Android Problems  with Sony PC Companion: step 6, image 1 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 6, image 2 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 6, image 3 of 3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  7. Factory Reset, Fix Android Problems  with Sony PC Companion: step 7, image 1 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 7, image 2 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 7, image 3 of 3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • '''Android WinUSB drivers'''
  8. Factory Reset, Fix Android Problems  with Sony PC Companion: step 8, image 1 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 8, image 2 of 3 Factory Reset, Fix Android Problems  with Sony PC Companion: step 8, image 3 of 3
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
114 other people completed this guide.
ZFix
195,994 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
26 Guide Comments
thanks so much. btw if it says you should unlock first, just press emergency calls and it accepts it
Godstime Osarobo - Reply
my xperia ( LT22i ) is not listed
abdul azeem - Reply
there is an error every time i try to use pc companion
error code: uegetphoneinfofailure
leo leo - Reply
there are an error
I can't download the upgrade on my phone
arnold - Reply
Past 24 Hours: 13
Past 7 Days: 44
Past 30 Days: 157
All Time: 234,234
