Fahrenheit FHT 125PRMR Power Cord Replacement
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: step 1, image 1 of 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: step 2, image 1 of 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: step 3, image 1 of 2 Fahrenheit FHT 125PRMR Power Cord Replacement: step 3, image 2 of 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: step 4, image 1 of 2 Fahrenheit FHT 125PRMR Power Cord Replacement: step 4, image 2 of 2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: step 5, image 1 of 1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
4 other people completed this guide.
Joshua Potts
265 Reputation
1 Guide authored
IUPUI, Team 2-2, Harley Fall 2016 Member of IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Members
4 Guides authored
3 Comments
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Reply
Where do you buy the power cord?
Dominique - Reply
probably available at electronic store
john john - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,485
