Fairphone 1 Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Fairphone 1 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 3 Fairphone 1 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 3 Fairphone 1 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  2. Fairphone 1 Motherboard Assembly Replacement: step 2, image 1 of 1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  3. Fairphone 1 Motherboard Assembly Replacement: step 3, image 1 of 2 Fairphone 1 Motherboard Assembly Replacement: step 3, image 2 of 2
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  4. Fairphone 1 Motherboard Assembly Replacement: step 4, image 1 of 3 Fairphone 1 Motherboard Assembly Replacement: step 4, image 2 of 3 Fairphone 1 Motherboard Assembly Replacement: step 4, image 3 of 3
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  5. Fairphone 1 Motherboard Assembly Replacement: step 5, image 1 of 1
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  6. Fairphone 1 Motherboard Assembly Replacement: step 6, image 1 of 2 Fairphone 1 Motherboard Assembly Replacement: step 6, image 2 of 2
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  7. Fairphone 1 Motherboard Assembly Replacement: step 7, image 1 of 2 Fairphone 1 Motherboard Assembly Replacement: step 7, image 2 of 2
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  8. Fairphone 1 Motherboard Assembly Replacement: step 8, image 1 of 1
    • Remove the motherboard from the display assembly.
3 other people completed this guide.
Andrew Optimus Goldheart
508,605 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,409 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,378
