Fairphone 1 RF Cable Replacement
  1. Fairphone 1 RF Cable Replacement, Back Cover: step 1, image 1 of 3 Fairphone 1 RF Cable Replacement, Back Cover: step 1, image 2 of 3 Fairphone 1 RF Cable Replacement, Back Cover: step 1, image 3 of 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 RF Cable Replacement: step 2, image 1 of 3 Fairphone 1 RF Cable Replacement: step 2, image 2 of 3 Fairphone 1 RF Cable Replacement: step 2, image 3 of 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 RF Cable Replacement, Battery: step 3, image 1 of 3 Fairphone 1 RF Cable Replacement, Battery: step 3, image 2 of 3 Fairphone 1 RF Cable Replacement, Battery: step 3, image 3 of 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 RF Cable Replacement: step 4, image 1 of 1
    • Remove the battery from your Fairphone.
  5. Fairphone 1 RF Cable Replacement, SIM and MicroSD Card: step 5, image 1 of 3 Fairphone 1 RF Cable Replacement, SIM and MicroSD Card: step 5, image 2 of 3 Fairphone 1 RF Cable Replacement, SIM and MicroSD Card: step 5, image 3 of 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone 1 RF Cable Replacement: step 6, image 1 of 2 Fairphone 1 RF Cable Replacement: step 6, image 2 of 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
  7. Fairphone 1 RF Cable Replacement, Midframe Assembly: step 7, image 1 of 1
    • Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
  8. Fairphone 1 RF Cable Replacement: step 8, image 1 of 3 Fairphone 1 RF Cable Replacement: step 8, image 2 of 3 Fairphone 1 RF Cable Replacement: step 8, image 3 of 3
    • The midframe is secured to the display assembly by several small plastic clips.
    • Use an opening pick to carefully pry the midframe away from the display assembly.
    • Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
  9. Fairphone 1 RF Cable Replacement: step 9, image 1 of 2 Fairphone 1 RF Cable Replacement: step 9, image 2 of 2
    • Carefully round the corner, separating the midframe from the display assembly.
  10. Fairphone 1 RF Cable Replacement: step 10, image 1 of 1
    • After rounding the next corner, the midframe should be free along the bottom and the sides.
  11. Fairphone 1 RF Cable Replacement: step 11, image 1 of 3 Fairphone 1 RF Cable Replacement: step 11, image 2 of 3 Fairphone 1 RF Cable Replacement: step 11, image 3 of 3
    • Run the opening pick and pry along the top seam.
    • To avoid bending or damaging the opening picks, do not pry near to the power switch, USB port, or headphone jack.
  12. Fairphone 1 RF Cable Replacement: step 12, image 1 of 1
    • Separate any remaining clips and remove the midframe from the phone.
  13. Fairphone 1 RF Cable Replacement, Motherboard Assembly: step 13, image 1 of 3 Fairphone 1 RF Cable Replacement, Motherboard Assembly: step 13, image 2 of 3 Fairphone 1 RF Cable Replacement, Motherboard Assembly: step 13, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  14. Fairphone 1 RF Cable Replacement: step 14, image 1 of 1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  15. Fairphone 1 RF Cable Replacement: step 15, image 1 of 2 Fairphone 1 RF Cable Replacement: step 15, image 2 of 2
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  16. Fairphone 1 RF Cable Replacement: step 16, image 1 of 3 Fairphone 1 RF Cable Replacement: step 16, image 2 of 3 Fairphone 1 RF Cable Replacement: step 16, image 3 of 3
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  17. Fairphone 1 RF Cable Replacement: step 17, image 1 of 1
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  18. Fairphone 1 RF Cable Replacement: step 18, image 1 of 2 Fairphone 1 RF Cable Replacement: step 18, image 2 of 2
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  19. Fairphone 1 RF Cable Replacement: step 19, image 1 of 2 Fairphone 1 RF Cable Replacement: step 19, image 2 of 2
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  20. Fairphone 1 RF Cable Replacement: step 20, image 1 of 1
    • Remove the motherboard from the display assembly.
  21. Fairphone 1 RF Cable Replacement, Wi-Fi Antenna Daughterboard: step 21, image 1 of 1
    • Be careful to pry on the connector, not the socket.
  22. Fairphone 1 RF Cable Replacement: step 22, image 1 of 3 Fairphone 1 RF Cable Replacement: step 22, image 2 of 3 Fairphone 1 RF Cable Replacement: step 22, image 3 of 3
    Buy
    • Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
    • Use tweezers to pull the daughterboard data cable away from its socket.
  23. Fairphone 1 RF Cable Replacement: step 23, image 1 of 1
    • Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
    • Two 2.5 mm Phillips #000 screws
    • One 1.6 mm Phillips #000 screw
  24. Fairphone 1 RF Cable Replacement: step 24, image 1 of 2 Fairphone 1 RF Cable Replacement: step 24, image 2 of 2
    • The Wi-Fi antenna daughterboard is held to the front assembly by mild adhesive.
    • Use tweezers to gently pry the board up and remove it from the phone.
  25. Fairphone 1 RF Cable Replacement, Earpiece Speaker: step 25, image 1 of 3 Fairphone 1 RF Cable Replacement, Earpiece Speaker: step 25, image 2 of 3 Fairphone 1 RF Cable Replacement, Earpiece Speaker: step 25, image 3 of 3
    • The earpiece speaker is held to the back of the display assembly with some mild adhesive.
    • Use the tip of a spudger to gently pry the speaker up from the display assembly.
    • Remove the speaker.
  26. Fairphone 1 RF Cable Replacement, RF Cable: step 26, image 1 of 3 Fairphone 1 RF Cable Replacement, RF Cable: step 26, image 2 of 3 Fairphone 1 RF Cable Replacement, RF Cable: step 26, image 3 of 3
    • Remove the antenna interconnect cable from the display assembly.
    • The three sections of the cable with exposed metal fit into the grounding clips on the side of the display assembly.
Jasper Fleischhauer
36,583 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 48
All Time: 3,655
