Fairphone 2 Battery Replacement
  1. Fairphone 2 Battery Replacement, Slim Case: step 1, image 1 of 3 Fairphone 2 Battery Replacement, Slim Case: step 1, image 2 of 3 Fairphone 2 Battery Replacement, Slim Case: step 1, image 3 of 3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Battery Replacement: step 2, image 1 of 3 Fairphone 2 Battery Replacement: step 2, image 2 of 3 Fairphone 2 Battery Replacement: step 2, image 3 of 3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Battery Replacement: step 3, image 1 of 1
    • Remove the front part of the slim case.
  4. Fairphone 2 Battery Replacement, Battery: step 4, image 1 of 3 Fairphone 2 Battery Replacement, Battery: step 4, image 2 of 3 Fairphone 2 Battery Replacement, Battery: step 4, image 3 of 3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
10 other people completed this guide.
Tobias Isakeit
123,785 Reputation
189 Guides authored
One Comment
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
Jim Kinnibrugh - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 26
All Time: 133,101
