Fairphone 3 Battery Replacement
  1. Fairphone 3 Battery Replacement, Back Cover: step 1, image 1 of 2 Fairphone 3 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 3 Battery Replacement: step 2, image 1 of 3 Fairphone 3 Battery Replacement: step 2, image 2 of 3 Fairphone 3 Battery Replacement: step 2, image 3 of 3
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Fairphone 3 Battery Replacement, Battery: step 3, image 1 of 2 Fairphone 3 Battery Replacement, Battery: step 3, image 2 of 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Fairphone 3 Battery Replacement: step 4, image 1 of 2 Fairphone 3 Battery Replacement: step 4, image 2 of 2
    • Lift the battery out of its recess and remove it.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
17 other people completed this guide.
Dominik Schnabelrauch
251,530 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,220 Guides authored
4 Guide Comments
Vielen Dank!
Einfach und direkt umgesetzt..
carola kamp - Reply Share
Imagine if all cellphone producers made it this easy :-)
Martin Andre Bae Pedersen - Reply Share
Anything to keep in mind, e.g. should I first give the phone a full charge once the new battery is installed?
Luke D - Reply Share
Where can I get the battery in Nigeria, if not how can I get one coz the one on my phone is weak
Mueez - Reply Share
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 147
All Time: 11,788
