Fairphone 5 Loudspeaker Replacement
  1. Fairphone 5 Loudspeaker Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Fairphone 5 Loudspeaker Replacement, Pry up the back cover: step 2, image 1 of 2 Fairphone 5 Loudspeaker Replacement, Pry up the back cover: step 2, image 2 of 2
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
  3. Fairphone 5 Loudspeaker Replacement, Remove the back cover: step 3, image 1 of 3 Fairphone 5 Loudspeaker Replacement, Remove the back cover: step 3, image 2 of 3 Fairphone 5 Loudspeaker Replacement, Remove the back cover: step 3, image 3 of 3
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
  4. Fairphone 5 Loudspeaker Replacement, Remove the battery: step 4, image 1 of 3 Fairphone 5 Loudspeaker Replacement, Remove the battery: step 4, image 2 of 3 Fairphone 5 Loudspeaker Replacement, Remove the battery: step 4, image 3 of 3
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
  5. Fairphone 5 Loudspeaker Replacement, Unfasten the loudspeaker: step 5, image 1 of 2 Fairphone 5 Loudspeaker Replacement, Unfasten the loudspeaker: step 5, image 2 of 2
    • Use a Phillips driver to remove the five 4.9 mm‑long screws securing the loudspeaker.
  6. Fairphone 5 Loudspeaker Replacement, Remove the loudspeaker: step 6, image 1 of 3 Fairphone 5 Loudspeaker Replacement, Remove the loudspeaker: step 6, image 2 of 3 Fairphone 5 Loudspeaker Replacement, Remove the loudspeaker: step 6, image 3 of 3
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right corner of the loudspeaker.
    • Pry up the loudspeaker and pull it away from the bottom edge of the phone to separate it from the frame.
    • During reassembly, insert the bottom edge of the loudspeaker into its slot in the frame before pressing the loudspeaker into place.
Alex Diaz-Kokaisl
129,264 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 256
