Fairphone 5 Ultra-Wide Camera Replacement
  1. Fairphone 5 Ultra-Wide Camera Replacement, Prepare your phone for disassembly: step 1, image 1 of 1
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Fairphone 5 Ultra-Wide Camera Replacement, Pry up the back cover: step 2, image 1 of 2 Fairphone 5 Ultra-Wide Camera Replacement, Pry up the back cover: step 2, image 2 of 2
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
  3. Fairphone 5 Ultra-Wide Camera Replacement, Remove the back cover: step 3, image 1 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the back cover: step 3, image 2 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the back cover: step 3, image 3 of 3
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
  4. Fairphone 5 Ultra-Wide Camera Replacement, Remove the battery: step 4, image 1 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the battery: step 4, image 2 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the battery: step 4, image 3 of 3
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
  5. Fairphone 5 Ultra-Wide Camera Replacement, Unfasten the connector cover: step 5, image 1 of 2 Fairphone 5 Ultra-Wide Camera Replacement, Unfasten the connector cover: step 5, image 2 of 2
    • Use a Phillips driver to remove the 3.9 mm-long screw securing the top unit connector cover at the bottom left corner.
    • The connector cover is labeled with a "1" and a triangle pointing downward.
  6. Fairphone 5 Ultra-Wide Camera Replacement, Pry up the connector cover: step 6, image 1 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Pry up the connector cover: step 6, image 2 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Pry up the connector cover: step 6, image 3 of 3
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the left edge of the connector cover.
    • Pry up the cover to separate it from the top unit.
    • The cover is connected to the top unit by a plastic cord. Don't try to completely remove it from the top unit.
  7. Fairphone 5 Ultra-Wide Camera Replacement, Disconnect the top unit: step 7, image 1 of 2 Fairphone 5 Ultra-Wide Camera Replacement, Disconnect the top unit: step 7, image 2 of 2
    • While holding the cover out of the way, use a spudger to pry up and disconnect the top unit press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  8. Fairphone 5 Ultra-Wide Camera Replacement, Unfasten the top unit: step 8, image 1 of 2 Fairphone 5 Ultra-Wide Camera Replacement, Unfasten the top unit: step 8, image 2 of 2
    • Use a Phillips driver to remove the six 4.9 mm‑long screws securing the top unit.
  9. Fairphone 5 Ultra-Wide Camera Replacement, Remove the top unit: step 9, image 1 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the top unit: step 9, image 2 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the top unit: step 9, image 3 of 3
    • Insert the flat end of a spudger under the screw hole along the bottom edge of the top unit.
    • Pry up to release the clips securing the top unit to the phone frame.
    • During reassembly, insert the top edge of the top unit at a downward angle into the frame before pressing it down and re-engaging the clips.
  10. Fairphone 5 Ultra-Wide Camera Replacement, Disconnect the ultra-wide camera: step 10, image 1 of 2 Fairphone 5 Ultra-Wide Camera Replacement, Disconnect the ultra-wide camera: step 10, image 2 of 2
    • There are small surface-mounted components surrounding the ultra-wide camera's press connector. Be careful not to pry against the components during this step, as you risk accidentally breaking them off of the motherboard.
    • Insert the tip of a spudger under the bottom right corner of the ultra-wide camera press connector.
    • Lift straight up with the spudger to disconnect the ultra-wide camera.
  11. Fairphone 5 Ultra-Wide Camera Replacement, Remove the ultra-wide camera: step 11, image 1 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the ultra-wide camera: step 11, image 2 of 3 Fairphone 5 Ultra-Wide Camera Replacement, Remove the ultra-wide camera: step 11, image 3 of 3
    • Use a spudger, or your fingers, to lift the ultra-wide camera out of its slot in the frame.
    • Be careful to not touch the lens on the other camera during this procedure.
    • Remove the ultra-wide camera.
Alex Diaz-Kokaisl
129,264 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 143
